having posted a for sale item in that section about wheel refurbing (check it out) i suppose it would be more suited in this one.
MACHINING
right this is something i can do as a favour etc, bearing in mind if i have the material, if not you guys have to source that or i can at cost.
if you need anything machining with regards to spacers, mounts, brackets etc.
basically anthing that needs turning, milling, drilling, tapping and i can also press bush's out seen as i am a hydraulic/mechanical engineer and am surrounded by F££(%£)G pressess all day. just drop me a line and i am happy to help.
aslong as it only costs me my time its not a problem
