 J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS
2 posters
J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS Empty
PostSubject: J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS   J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS EmptyThu Jul 19, 2012 6:41 am
J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS 8865173f41ff3912
J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS Logos
Are your wheels looking old? Curbed? Scuffed? Scratched? Corroded? or just fancy a colour change?
To do these process’ companies are charging upwards of £60 a wheel depending on type and size.
Basically here’s the process:
· Remove tyres where required
· Remove previous balancing weights
· Alloys are chemical strip soaked to remove majority of old paint/laquers etc
· Wheels are bathed in hot cleaner
· Wheels are jet washed to remove all residue
· Then wheels are bead blasted to remove remaining coatings and to give paint a good key and even finish
· Kerb damage and scuffs are then taken out using hand polishing or a lathe
· If power coat option is taken the wheels are then powder coated
· Laquer which is optional for powder coating, which is then applied and baked on
· Tyres are then re-fitted if required
· Wheels then balanced if required
· Tyres are filled with air ready to roll
· For automotive paint finish’s the wheels are treated with etch primer
· Then sprayed with high quality paint via compressor with multiple coats
· Wheels are then laquer baked
· For split rims the wheels are taken fully apart
· The nuts/bolts sent for chemical strip and nickel plate
· The barrels are then stripped/soaked/washed/blasted and damage removed as above
· The barrels can either go the power coat or automotive spray route
· They are then laquer baked
· The lips are then taken through various grits till a good finish is achieved
· The lips then get mirror compound polished
Price list:
Price per wheel, based on 17” inch
Tyre taken off £4
Tyre put on £4
Wheel balanced £4
Wheel chemical stripped £10
Wheel blasted £15
Wheel powder coated £20
Wheel automotive paint sprayed £15
Wheel heat laquered £10
Mirror polished lips £20
Bolts for splits chemical stripped and nickel plated £20
Average cost per set, without tyres, based on 17” wheel
Average cost for standard set of 4 alloys refurbed and powder coated without laquer
£165
Average cost for standard set of 4 alloys refurbed and sprayed/laquered
£190
Average cost of 4 split rim barrels with mirror polished lips refurbed
£260
all prices subject to change, if you would like a touch up etc just get in touch.
wheel/barrel colours of powder coating to be black so far
wheel/barrel colours of automotive sprayed wheels can be any off the shelf colour
all wheels/tyres to be dropped off and collected.
5-10 working day turn around where possible
I will not repair/alloy weld structural damage and/or straighten buckled wheels
DIYPERFORMANCE.NET MEMBERS WILL RECEIVE AN EXCLUSIVE 10% DISCOUNT
INTERESTED?
DROP A P.M ON DIYPERFORMANCE.NET
ADD ME ON F.B, JAMES SMITH (BOONA575575@HOTMAIL.CO.UK)
GIVE ME A CALL OR TXT: 07866878044
PostSubject: Re: J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS   J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS EmptyThu Jul 19, 2012 8:55 am
nice one matey Very Happy
PostSubject: Re: J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS   J.S PERFORMANCE WHEELS, ALLOY WHEEL REPAIRS, EXCLUSIVE 10% DISCOUNT FOR ALL DIYPERFORMANCE MEMBERS EmptyThu Jul 19, 2012 9:19 am
i will always do my best with this in terms of quality and price.
the prices are a rough guide, i obviously dont want to loose money on them, am not in it for huge profits i have a good job and i kind of like seeing the wheels when there done.
keep your eyes on this for some before and after pics.
sure i could sort you a little cheaper berry! been as you've done me fair few favours in the past.
i have to pay a guy to take tyres off/on
to balance wheels
a guy to blast them or pay a little to use his blaster depending
a family friends firm to powder coat
families firm to nickel plate bolts
i pay for all polishing discs/compound/grit wheels/paper/fuel costs/laquer/paint/gas to heat wheels/stripping chemical
it all adds up, so once i've done a few more sets i will have a definate idea of costs, it could go up or down slightly, the above is just a guide per set.
cheers for reading
» AP Tyres Parkgate - Tyres, alloy wheel refurb and repair
» Alloy wheel blasting
» 18" Dotz Roadster Alloy Wheels 5X100 225/40/18
» 17" porsche cup 2 style alloy wheels 5x100
» 15'' Rota grid lightweight alloy wheels.
DIY Performance :: Recommended Retailers-
