| Car Camera Rig! | |
Posts : 545 Join date : 2012-04-24 Age : 33 Location : sheffield
| Subject: Car Camera Rig! Fri Nov 16, 2012 8:02 pm | |
| Subject: Re: Car Camera Rig! Fri Nov 16, 2012 8:07 pm | |
| Subject: Re: Car Camera Rig! Fri Nov 16, 2012 8:36 pm | |
| either of those could work but the desiding factor is the combined weight of both the arm and camera, looking at the first photo i would say that its using a light weight alloy arm and not scaff bar, ill hava a think at work. | |
| Subject: Re: Car Camera Rig! Fri Nov 16, 2012 8:49 pm | |
| Aye! Wouldnt use scaff bar! Heavy stuff! Thinking more ali pipe!
Or possibly a peice of pvc pipe, with a slightly small pvc pipe inside with a bolt thru each end to stop it from flexing as much? Hmmm
Might pop to bnq n try that as its only a few quid! | |
| Subject: Re: Car Camera Rig! Fri Nov 16, 2012 8:56 pm | |
| or even a piece of pvc with a suspension bridge style support? | |
| Subject: Re: Car Camera Rig! Fri Nov 16, 2012 9:42 pm | |
| getting a bit over kil, a suspension arm wont stop any 'sway' it just gives it a safe working area (if that makes sense) i rekon the best idea would be to trak some alloy pipe down, what about speeking to gav at race spec, and find out what the longest pieces of streight boost pipe are that he can gt, and ten just join two of them together? | |
| Subject: Re: Car Camera Rig! Fri Nov 16, 2012 9:51 pm | |
| Lol! I like to make things over complex haha!
Thats a good idea! Ill get in touch with him!
The shots will actualy be taken at 2/3mph! Thats all it needs, plus means it can be dome with engine off to stop vibrations! | |
| Subject: Re: Car Camera Rig! Sat Nov 17, 2012 3:26 am | |
| Built a quick rig this afternoon! Failed!! when i put one sucker on the other pops off!, need a system where i attach the suckers and then attach the beam after! But hay ho! it was a start! Also PVC aint rigid enough! | |
| Subject: Re: Car Camera Rig! Sat Nov 17, 2012 4:16 am | |
| thats not a bad atempt though, 10 points for effort | |
Posts : 175 Join date : 2012-05-29 Age : 38 Location : Rotherham
| Subject: Re: Car Camera Rig! Sat Nov 17, 2012 9:30 am | |
| U have roof rails, use a clamp then you don't have to worry about suckers comin off etc | |
Posts : 321 Join date : 2012-06-13 Age : 33 Location : Sheffield
| Subject: Re: Car Camera Rig! Sat Nov 17, 2012 3:20 pm | |
| I'd cable tie it. Just cause I'm a hard bastard | |
| Subject: Re: Car Camera Rig! Sat Nov 17, 2012 5:26 pm | |
| ha ha, team tie wrap ftw yo | |
| Subject: Re: Car Camera Rig! Sat Nov 17, 2012 9:21 pm | |
| Cheers lads! It would work but not safe enough for my liking!
Lol could cable tie it to mine, but that would only work for my car and noone elses! :/ | |
Posts : 256 Join date : 2012-07-01 Age : 31
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 1:17 am | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 6:16 am | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 10:21 pm | |
| That looks like a rate cool idea Andy, I wunder if the weight might be an issue? | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 10:37 pm | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 10:39 pm | |
| jesus!!!!! plenty to go at then | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 10:47 pm | |
| Yup! Looks like im gonna be busy reading for a while! Lol! Gonna be a nice winter build tho | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 11:02 pm | |
| oh yea lol never thought of the weight | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 11:10 pm | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 11:17 pm | |
| steady on, ive got an old drum kit at my parents house, but the stands are rate heavy, there designed to be because when you hit a symbal you dont want it to fall over | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 11:29 pm | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 11:42 pm | |
| yes they can work, i kinda get where your headin, ill have a think | |
| Subject: Re: Car Camera Rig! Mon Nov 19, 2012 11:46 pm | |
| Sweet man!
For the pole, looking at 2" aluminium tube, can get 5meters for £25 ish | |
| Subject: Re: Car Camera Rig! | |
| Car Camera Rig! | |
