  Shaking
tottybye
PostSubject: Shaking   Fri Jan 04, 2013 5:57 am
My sister drive a Corsa D (CAT D) atm. When you reach about 40mph the car starts to shake then 45mph plus it stops. Has anyone any ideas what it could be.
P.S Damage was front end drivers side
Cheers
write off ryan
PostSubject: Re: Shaking   Fri Jan 04, 2013 7:23 am
it could that her wheels need balancing but someone else will help as i dont know much Smile lol
PostSubject: Re: Shaking   Fri Jan 04, 2013 10:13 am
is there any bodywork damage that effects the aerodynamics?
PostSubject: Re: Shaking   Fri Jan 04, 2013 11:47 am
Sounds like wheels need balancing
PostSubject: Re: Shaking   Fri Jan 04, 2013 8:14 pm
Defanetly balancing on the wheels, any tyre fittes, quick fit etc can sort it, but I'd get tracking checked at same time, just to be sure its all ok after the damage repairs.
PostSubject: Re: Shaking   Fri Jan 04, 2013 9:17 pm
i had images of a panel flapping about lol, thought wheel balancing was too simple!
PostSubject: Re: Shaking   Fri Jan 04, 2013 9:42 pm
It's the way it stops at 45plus makes me pritty sure its ballancing
PostSubject: Re: Shaking   Sat Jan 05, 2013 12:11 am
I would have said balancing too for that exact reason
tottybye
PostSubject: Re: Shaking   Sat Jan 05, 2013 3:30 am
Should have put this in my first post. the cars had 4 new tyres, wheels checked, balenced and tracking sorted. ive also replaced a bar underneath engine bay which was bent.
PostSubject: Re: Shaking   Sat Jan 05, 2013 7:00 am
I've had to nip back to the tyre place loads of times to get a new tyre re-balanced, still might be worth the journey if you're not 100% sure it's not the tyre at fault, if it was recent that you had they tyres done it won't cost you anything as they didn't balance it up properly in the first place or a weight has managed to come off.
Like I said, easier to check that first as opposed to spending a small fortune hunting down an unknown fault.
tottybye
PostSubject: Re: Shaking   Sat Jan 05, 2013 7:57 am
All wheels have been balenced twice. It's hard to explain but it just doesnt feel like the wheels. Confused Question scratch
PostSubject: Re: Shaking   Sat Jan 05, 2013 8:51 am
Anti roll bushes?
Shaking
» Head shaking
» Easy Pan wanted
» Crazy Wrestlemania Thought
» new shaker table gets 98% of the gold
