 Gauges on a motorbike
PostSubject: Gauges on a motorbike    Wed Jan 16, 2013 8:02 pm
What do you actually connect a Fuel/Air ratio gauge to to get a reading ?
Would it be possible to do on a bike ? Be quite cool and a bit different on a bike Smile
PostSubject: Re: Gauges on a motorbike    Wed Jan 16, 2013 8:48 pm
Dunno about a bike but it connects to the lamba sensor on the exhaust and measures the apropriate gas levels, this then sends a signal to the ecu, its the signal that you tap into and gives the gauge somthing to 'read' do bikes run lamba sensors? Thought yours was carb? Tbh there might be an af gauge on the market that gets a signal another way but I bet its not cheep Neutral
PostSubject: Re: Gauges on a motorbike    Wed Jan 16, 2013 9:20 pm
No my bike is fuel injected but bike I'm planning on getting is carb
