 polybush engine mounts
View previous topic View next topic Go down
PostSubject: polybush engine mounts   Tue Feb 05, 2013 3:28 am
Just a heads up really
There is the old trick of packing the engine mounts with tigerseal or silkaflex
I was a little sceptical at first when i herd this but after a while of it eating at my mind and hearing it from several places,
Ive done it now to the justy diff mounts and one rear engine mount and what a massive difference, the whole back end is much stiffer
At one tube around ,£10 its far much cheaper and easier than poly bush mounts to fit,
Its best to remove the mount and fill it up then leave it to set but i did mine on the car and left it overnight with no problems
I would say one tube is adequate to do a set of engine mounts
Hope it helps people
PostSubject: Re: polybush engine mounts   Tue Feb 05, 2013 5:39 am
Perfect info matey, and photos? I need to do my front two ready for pod next week ;-)
Bazz
PostSubject: Re: polybush engine mounts   Sun Mar 24, 2013 3:47 pm
tank whats that website you were on about for bushes??
PostSubject: Re: polybush engine mounts   Mon Mar 25, 2013 8:26 pm
Strong flex, there the cheepest, bassed in polland, but bludy good quality and value for money
View previous topic View next topic Back to top
» V8 Swap engine mounts?
» BOB engine mounts?
» Solid Engine mounts
» Front rubber engine mounts
» Engine Mounts
