 Typical corsa issues?
nick94
PostSubject: Typical corsa issues?   Thu Apr 04, 2013 2:38 am
Hey. Okay typical corsa problems, air bag light is still on after being properly plugged in does it need resetting or something? secondly the horn, all the switches and wires are in tact I've bought a new horn and that still doesn't work when it's been fitted, what shall I do next?
PostSubject: Re: Typical corsa issues?   Fri Apr 05, 2013 5:09 am
Air bag light, take the bulb out. Problem 1 solved.
Horn. Join the club. I dont have one either.. Fit your horn on a switch.
Problem 2 solved haha
PostSubject: Re: Typical corsa issues?   Fri Apr 05, 2013 12:20 pm
Ha ha, typical vauxhall, be carfull if u pull the bulb out cos it needs to be there for an mot, but not if you havnt got an air bag fitted, as for the horn, typical vauxhall problem, but check the fuse, then wiring, then the button in the wheel, they somtimes where out, and your squib, bit that sits round on the back of the steering wheel, they somtimes clog up with shit or the spring on the colum doesn't push the pin in enough to make contact, failing that lot, is rewire the horn in seprate to the normal loom, streight of the battery, then it can't go wrong
nick94
PostSubject: Re: Typical corsa issues?   Sat Apr 06, 2013 3:34 am
I've noticed as I turn the wheel there is something cracking behind the steering wheel every now and then the squib nackerd then?
jowley
PostSubject: Re: Typical corsa issues?   Tue Apr 09, 2013 7:18 am
it sounds like its down to that, diagnosis machine will take the light out, have you got a live and earth tester? make sure you have a live and earth at the horn then you can trace the fault back.....but it sound like the ring is the problem.
» KWA SR-12 Feeding issues
» SUNBURN ISSUES!!!!!!
» ODC 420 .. Issues .. may have to get a new tube :(
» 460 Issues
» Garrett Sea Hunter Mark 2 underwater detector
