 USB Car Ports
4 posters
Kon
USB Car Ports Empty
PostSubject: USB Car Ports   USB Car Ports EmptyWed May 09, 2012 12:08 pm
yo, im new to forum but got a few things to share as i may be able to help people with some cool ideas and cheap solutions!
so i just got my first car from Shrek (1.9D Polo) and its been sat on Priestley's drive uninsured for the last 3 weeks which has given me some time to come up with some mega cool ideas.
the main necessity in a car these days is a phone and i use mine for everything from music to satnav and battery soon dies. one of the min things about charging your phone is that you have to have a massive dildo stuck out of your fag lighter and 100 wires.
i started wiring USB ports in permanently fused at 1A and with a switch rather than unplugging your dildo dash charger!
my first project was Priestleys car, we ripped up an old USB charger and plugged everything in:USB Car Ports 419686_10150667948256343_559041342_11337664_1734189454_n
only to find that it wouldn't charge an iphone.
-apple are wankers.
so USB has 4 wires. Red(+) Black(-) Green(Data+) White(Data-) and usually you only have to loop the data lines to make your phone start charging, however Apple decided that you have to have between 2-3v travelling through your data lines to be able to charge an iPhone enabling Apple to add another 10 quid on a phone charger because you cant use a normal one.
anyway we added some cheeky resistors to drop 3v over the datalines making Priestleys normal charger an iphone one all for the cost of 90p:
USB Car Ports 426513_10150667943561343_559041342_11337643_1244286449_n
with the hard part sorted we drilled on hole for the USB Face panel (25mm) and mounted a switch, rapped everything up and BOOM he's charging like a BOSS and not dildo dash charger!:
USB Car Ports 426968_10150667944321343_559041342_11337648_834096737_n.
once i knew it would work i took the knife to my car and heres what i got a different style hidden USB with toggle and indicating light:USB Car Ports 534860_10150918586576343_559041342_11956376_21782661_n
Once i mastered these few different styles and ways i decided to make shrek a USB charger for his new project from scratch and after alot of testing and few late nights and overlayed work mornings ive finally sussed it!
so this is whats its made from:
USB Car Ports 576559_10150907451936343_559041342_11948317_1872427470_n
-50kOHM resistor x2
-100kOHM resistor x1
-150kOHM resistor x1
-10uF capacitor x2
-0.1uF capacitor x1
-5v positive voltage regulator at 1A x1
all of this cost around £3 the type of usb panel mount depends on how much you want to pay for it. £2 for stealth, £5 for big ones.
soldering circuit building and testing:
USB Car Ports 528848_10150907446951343_559041342_11948290_1099155876_n
USB Car Ports 562501_10150907447606343_559041342_11948291_1918790094_n
USB Car Ports 523866_10150907449646343_559041342_11948301_1349806510_n
So final product ready to fuse and crimp straight to + & - at 1A fused:
USB Car Ports 543286_10150907450441343_559041342_11948304_974927952_n
this cost around £5 to build so if anyone would like one putting together for their car then give me a shout and ill be happy to help! also if anyone want the circuit diagram to make your own just holla at me and ill draw you one up!
keep an eye out more mad projects coming!
USB Car Ports Empty
PostSubject: Re: USB Car Ports   USB Car Ports EmptyWed May 09, 2012 10:13 pm
I'm very impressed mate, top work and a quality photo thread, well done matey, keep it up
USB Car Ports Empty
PostSubject: Re: USB Car Ports   USB Car Ports EmptyFri May 11, 2012 7:24 am
Electrics like that baffle my mind, mention resistor or circuit board sand whoosh straight over my head. Looks good though bud
USB Car Ports Empty
PostSubject: Re: USB Car Ports   USB Car Ports EmptySat May 12, 2012 7:49 pm
I eh I new how to wip up stuff like that good job mate Smile
https://diyperformance.forumotion.co.uk
USB Car Ports Empty
USB Car Ports
