Andy_K
Posts : 40 Join date : 2012-10-17 Location : Sheffield
| Subject: good garages for fitting lowering springs? Mon Apr 29, 2013 11:32 pm | |
| Can anyone recommend anywhere for fitting a set of four lowering springs in Sheffield? Its for a MK3 Mondeo TDCi if that makes any difference, and I will supply the new springs. Place I usually use quoted £240 +vat to do it, more if its a ballache getting pinch bolts out. Would like to see if anyone know anywhere that might do it a bit cheaper before I go and book it in :/ | |
| Subject: Re: good garages for fitting lowering springs? Tue Apr 30, 2013 10:48 am | |
| without sounding prude, could you do it your self? cant the that hard on a modeo, i think that the front are std mc pherson struts and the rear are coil over spring type, so the hardest tool youll use is realy the spring compressor tool, or do modeos that age have trick suspension? deano might be your man, actually how soon do you need it doin? when jared comes back of holiday, think its next week, he can do it for you, hes just been made redundant, but hes a full blown mechanic | |
Andy_K
| Subject: Re: good garages for fitting lowering springs? Tue Apr 30, 2013 6:18 pm | |
| I probably could do it myself tbh - did the saxo so can't see being much different. Just not really got the time at the minute so would rather take it somewhere and let them do it | |
| Subject: Re: good garages for fitting lowering springs? Wed May 01, 2013 3:02 am | |
| Jareds your man then, send him a pm, I'm sure he'll reply ASAP | |
| Subject: Re: good garages for fitting lowering springs? | |
