| stupid astra | |
+6shakeyjakegsi boona575 Mexican tank2023 Jaz1889 shrek 10 posters |
| Subject: stupid astra Sat Apr 21, 2012 8:00 am | |
| well been as we are trying to get the biggest spec lists i thought id better make one for the astra right then its a 1.6 standard astra........ officer......... ha ha ha ha ha ha ha ha spec (atm but gonna get bigger) cavalier sri 130 8 v engine (seh) 130bhp standard, aiming for 240bhp, around 270bhp with nos engine - mauhle racing pistons (forged) let piston rings arp bolts metalhead gaskit kit hardend head bolt kit new crank bearings uprated oil pump (to feed turbo aswell as head) kent cams high lift cam hydraulic followers with uprated springs to aid compression uprated fuel injection rack bosch red injectors(fromsaab turbo- biggest you can get same as cosworth reds) oil catch tank and modified breather setup fixed rate adjustable fuel pressure regulator t3 turbo front mount intercooler from colt turbo (not big enough need a bigger one) 2lter radiator slim line racing fan, modified water colant system, high flow thermostate black diamond racing padel clutch f18 d gearbox (close ratio 1-4 massive 5th gear with high torque bearings) gsi drive safts and 'big' hubs gsi brakes with red dot racing disks omp front strutbrace various chrome bosst pipes various silicone pipes, inside its got hks turbo timmer air to fuel ratio gauge boost gauge vacume gauge oil pressure gauge suspension is lowwered 80mm all round but i think it needs more and up rated shocks, parts ive got sat in the garage that need fitting, front mount oil cooler (13 core mocal jobie) scooby wrx bucket seats small steering wheel rear strutbrace twin piston dump valve (thanks call) parts i need to get polybush (trak down a supplier - these are getting hard to find now) nos (from tank- i oh you big time) MASSIVE front mount intercooler (if ive got half a chence of beeting callum) BIGGER turbo (if i win the sodding lottery, theres so damn expensive) more boost pipe to fit new intercooler (i think callum micht be able to help out here as long as joss hasnt nicked it all, little sod lol ) plastic for window conversion jobs i need to do, finish exhaust system bleed brakes with big caliper conversion completly strip the interior, if ive got anychance of making this thing shift then i have to get the weight down (that allso means i'm going on a diet for pod lol) if any of you now me and my past cars, when i strip it imean i realy strip it, i need to get hold of some poly carb to make my own light weight windows, normal glass is to heavy make the sodding dump valve work properly thats about it atm, but plans always change, there aint no point with photos atm, just look at any other astra 4 door mk3 and your about there the wholepoint of it is to be a major sleeper, nothing on the outside makes this car look like a scooby killer, thats the whole point comments welcome | |
| Subject: Re: stupid astra Sat Apr 21, 2012 8:14 am | |
| could do with some 14'' wheels as well, smaller wheels = faster acceleration | |
Jaz1889 Admin
Posts : 292 Join date : 2012-04-10 Age : 34 Location : Sheffield
| Subject: Re: stupid astra Sat Apr 21, 2012 9:01 am | |
| Pictures please what a list I wish I could have that list | |
| Subject: Re: stupid astra Sat Apr 21, 2012 9:38 am | |
| well this is actually one of my longest ever running projects, they usually dont take this long to build, but i geuss ive never wanted to get so much power out of it | |
Jaz1889 Admin
| Subject: Re: stupid astra Sat Apr 21, 2012 11:19 am | |
| Yeah true it is cool as owt | |
| Subject: Re: stupid astra Sat Apr 28, 2012 5:27 am | |
| quik update, interiors out, still got roof card to come out moved battery to boot all wired up- need the space for intercooler pipe work, moving up to 2 1/2 inch pipe work and want to do it all in alloy to help boost, wired up fan over ride and fitted small steering sheel, just need to fit them scooby seats and the interiors bassically ready, gota move some gauges around nought special then i can start back in the engine bay..................... | |
Jaz1889 Admin
| Subject: Re: stupid astra Sat Apr 28, 2012 6:02 am | |
| Cool cool keep it up dude | |
Posts : 254 Join date : 2012-04-12 Age : 33 Location : Possibly anywhere in the UK
| Subject: Re: stupid astra Sat Apr 28, 2012 7:23 am | |
| seems so weird reading the spec like that then checking it off in my mind whats been done, if you need a hand you know where to find me, more than likely at work or in some random dark greasy place lol i might do a spec list like that for justy now | |
| Subject: Re: stupid astra Sat Apr 28, 2012 9:16 am | |
| go for it mate, i keep thinking of more ideas to gain more power but i dont want to list it until i fit it ...... | |
| Subject: Re: stupid astra Tue May 01, 2012 7:24 pm | |
| quik update, new intercooler should be here friday and new turbo mid june but i could do with a mega squirt ecu, seats nearly in and new parts that have arived- -giant oil cooler -magnecore leads -25mm silicone hosing for iav my restrictions will now be the inlet manifold and exhaust manifold, need to save up for a new tubular manifold and custom inlet. but i might have to rob a bank before i can get them, at a geuss the power with the gear ive got is around 250, but if i get mega squirt, turbo and fir the injectors (cutesy of jared) should bw looking around the 300 mark, but if by some chance i get some cash and fit tubular manifold and a screamer pipe should be able to brake the 330bhp mark, which should put me around a 12.5 quater mile depending on how good i drive and the tyres am running watch this space, i promise ill put photos up soon | |
| Subject: Re: stupid astra Thu May 10, 2012 7:22 pm | |
| think 12.5 is very optemistic, oh well, right little update, fitted the scooby seats and i realy didnt get on with them so took them straight out and fitted some cobra buckets i picked up for a bargin price, so seats are in harness are in nos tanks in and all wired up bt i cant fit the jet ntil i get the new pipe work for the intercooler. oil coolers riged up but again i cant fit it until the new coolers in situ, new springs fitted all round to stiffen up the schassi a bit, whilst the wheels were of gave them a little re-furb and cleaned up the legs and brakes, changed the front drivers drive shaft as the original i fitted was from an early calibre and was actually 1/2 inch longer than a gsi one, making it a bugger to fit and putiing un wanted pressure on the box and engine, any way i piccked one up from a gsi that was fitted with a v6 so i know itll cope with the power i want to put on it, piped up the iav (thanks tank and rob) using a diy t piece, and fitted the hks dump valve (twin piston jobie) hopfully this one will work but hasnt't been properly tested yet thats about it atm, when i get some more cash ill finally get them intercooler and pipe work so i can make some more progress | |
Posts : 258 Join date : 2012-04-11 Location : Sheffield
| Subject: Re: stupid astra Fri May 11, 2012 5:37 am | |
| Love this car and will always be up to help ! even if its just taking wheels off or passing you tools ! Very special project this and its going to look amazing at pod ! | |
| Subject: Re: stupid astra Tue May 22, 2012 7:13 pm | |
| little update, new intercoolers fitted, finaly picked up fse rissing rate feul reg from jareds woo hoo lol, started chopping bumper up to try and fit around the intercooler, got all pipe work fitted for the cooler but could do with some more high pressure clips because ive ran out picked up some more parts, oil temp and pressure sender units, water temp sender unit, just got to fit it all now, need to track down an exhaust, or stop being a tight git and buy a hoffman race tube, could do with some poly bushes as well, any one know where i could get some, not having much joy, allso any one going to race spec any time soon? could do with a few more bits picking up lol | |
| Subject: Re: stupid astra Tue May 22, 2012 7:17 pm | |
| oh, and interiors ready, roof cards fully out, fitted scooby seats but didnt like them, so fitted some cobra seats i managed to get hold of quite cheep, oil coolers allso fitted, and moved slim line fan to get it all to fit and i still need some 14'' steelys if any one see's ought laying around spare lol. | |
| Subject: Re: stupid astra Tue May 22, 2012 8:32 pm | |
| Subject: Re: stupid astra Tue May 22, 2012 10:52 pm | |
| Looks so strange like that, needs some pics what its like now | |
| Subject: Re: stupid astra Tue May 22, 2012 11:15 pm | |
| Tbf, not that much has changed, only the interiors missing, rear Windows are black and so are the wheels, ride heights lowered and there's a back box hiding away under the back bumper, :-) | |
| Subject: Re: stupid astra Tue May 22, 2012 11:46 pm | |
| Still though little changes have big effects | |
| Subject: Re: stupid astra Wed May 23, 2012 12:47 am | |
| ha ha, well my only regret is that i didnt get one of the engine bay when i picked it up and then compare it to now, wish id have done a propper build thread like yours mate | |
| Subject: Re: stupid astra Wed May 23, 2012 12:52 am | |
| Pick one up for ya, theres a lad that comes mossies same as yours, you can just go peek-a-boo with yours though, mine everyone knows it down to details | |
| Subject: Re: stupid astra Tue Jun 12, 2012 10:28 am | |
| well things have developed a lot since last update, i will right up on all the changes, including nearly melting the bora exhaust with the astra, but a few more toys have just turned up so i can nearly get this thing up and running, then setup ready for pod | |
| Subject: Re: stupid astra Tue Jun 12, 2012 7:22 pm | |
| Subject: Re: stupid astra Tue Jul 10, 2012 11:36 pm | |
Posts : 248 Join date : 2012-07-03 Location : sheffield/barnsley
| Subject: Re: stupid astra Wed Jul 11, 2012 5:26 am | |
| dude!!! get some pics up you sick turbo man!! you surely gunna need standalone management for the mad amounts of air your pulling and yes the injectors to match the fuel levels. wanna see this..........PICS NOW please. | |
| Subject: Re: stupid astra Wed Jul 11, 2012 6:23 am | |
| i'll have a word with mexican see if hes got any to stick on, boona pm me your n.o., the mrs wants to give u a buzz | |
| Subject: Re: stupid astra | |
| stupid astra | |
